Sterling’s D’Anniballe on E-Fuel Marine Engines: ‘Definitely Doable’
Correspondent
Another noted engine builder's perspective, http://speedonthewater.com/in-the-ne...initely-doable
i don't think that "cheap" will be the case for the retrofit if you decide to set your boat up for e-fuel. unfortunately when you mention the word boat (break out another thousand), that's what comes to mind. e-fuel is simply a BAD deal all the way around
Correspondent
Mr. D'Anniballe called me with his perspective, and I want people to have another point of view from a credible source minus all the political debate that took over the last story thread. It isn't that the discussion was bad—I learned quite a bit—but it morphed into something that strayed a bit off topic.
Matt, sorry for sounding snarky, I was posting from my phone.
The tanks are the only issue raised in the article that are beyond a normal boater, IMO. SS tube and fittings are not cheap, but they are shiny and thus we boaters will gladly purchase them.
Aside from the tank, I'd think $2000-$3000 would get you ethanol ready. Couple hundred for a fuel pump, another couple for hoses/fittings, and then a tune. Of course, the cost of the last part could vary wildly.
One could probably coat an AL tank in situ to mitigate corrosion, but the fill hose would be a challenge, and I'm nearly certain it won't be economical.
Aside from the tank, I'd think $2000-$3000 would get you ethanol ready. Couple hundred for a fuel pump, another couple for hoses/fittings, and then a tune. Of course, the cost of the last part could vary wildly. One could probably coat an AL tank in situ to mitigate corrosion, but the fill hose would be a challenge, and I'm nearly certain it won't be economical.
Correspondent
