30 amp plug
Found a 30 amp plug on the starboard side under the throttles. Other than the refridge and one 120volt outlet in cabin what does it do? 2004 32 mcob
That should be your main shore power connection. There should be a breaker panel on your wetbar that has each accessory labeled. Usually there is an outlet, fridge, microwave, air conditioning or battery charger depending on the options.
