How to modify a flat bunk trailer to carry a stepped hull boat? >
Old 11-01-2014 | 01:25 PM
Default How to modify a flat bunk trailer to carry a stepped hull boat?
Need to use a flat bunk trailer to carry a stepped hull boat across the country. Single trip use. Any ideas?
cyrus77 is offline
Old 11-01-2014 | 03:34 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Screw 2x4s or whatever thickness needed to the top of the existing bunks. Be sure to countersink the screws below the surface of the wood at least 1/8". Staple some carpet over the top assuming the boat will be lifted on/off.
Sydwayz is offline
Old 11-01-2014 | 05:47 PM
Yep...usually 1 2x? Per step is how we set up lifts usually
Rbesola is offline
