What prop for a 25 Outlaw  525 efi? >
Old 11-01-2014 | 11:22 PM
Default What prop for a 25 Outlaw 525 efi?
For those of you with 25 Outlaws with 525 efi's, what prop are you seeing the best results with?
Revd Up is offline
Old 11-02-2014 | 06:20 PM
to get a base line I would try a 26p Bravo four bladé and try a 25p Mirage +, then tell BBlades what your results are and start the tuning program with him to get what works best for you. This is based on a Bravo outdrive w 1.5 ratio
pvan1 is offline
Old 11-02-2014 | 10:52 PM
From the response on this thread , there must not be many boats with this set up. The boat now has a 26 Bravo 1, Don't know any more specifics. Just was wondering what others have had success with..
Revd Up is offline
Old 11-03-2014 | 10:59 AM
525 efi is not that common in a 25 outlaw. What rpm are you turning the 26P Bravo?
RiReuter is offline
Old 11-04-2014 | 04:15 PM
agree, when I saw the thread, I thought a better title would be "does anyone have a 525 in a 25 Outlaw". I didn't think that would be a common set up, although very nice if you have it!
Enjoy!
imartin is offline
Old 11-04-2014 | 10:15 PM
I have a buddy in the process of buying one and thought Id just throw it out there to see what others are having the best success with. I agree this probably is a rare set up. It is a factory optioned boat with hydraulic steering and K planes. Probably won't have any performance information until next spring as our season is over. Anybody else have one with this set up?
Revd Up is offline
Old 11-05-2014 | 09:06 PM
My 25' Nordic Rage has a 500 EFI with a 28P Bravo 1 labbed by Bblades for mid range and I see 79 GPS all day long at 4950 RPM. If I drop the 4 optima batteries, wife, and both subwoofers the boat has seen 84 GPS. I had a 25 Baja before the Nordic and I would bet you see mid 80's out of yours with that power.
bikercrze1 is offline
Old 12-02-2014 | 10:31 AM
I have an '04 25 OL with a Raylar HP600 in it. I typically run a 28P B1 stock (which I hate) but it is the only prop I own for it. I've tried a 26P merc labbed B1 which was perfect for the boat, I could spin it up to 5500-5600 RPM. I'd guess the best FOR MINE would be the 28P, labbed but turned down to 27P, and run it in the 5300-5500 RPM range. So with the 525 I'd say the 26P would be perfect. I've also tried the Hydromative props and didn't like them at all.
Baja_man is offline
Old 12-02-2014 | 12:04 PM
That's great to know. The prop that is on it looks to be a labbed 26 Bravo 1. Once spring comes we will have some numbers to work off of. His is also a "04 25 Outlaw but does not have the SST graphics.
Revd Up is offline
Old 12-02-2014 | 12:21 PM
Prop that 525 to bump the rev limiter in ideal conditions. 5,200 - 5,400 rpm is where the power is. My boat is a 22 Donzi 525 with a 30p Bravo 1. If your drive is deep and a 3 blade hooks up the M+ might be faster.
thirdchildhood is offline
