CMI Tails with Silent Choice/Y-Pipes & Actuator >
Old 11-03-2014 | 02:35 PM
seafordguy's Avatar
Default CMI Tails with Silent Choice/Y-Pipes & Actuator
These are CMI Tails for Bravo application. These are the muffler clamp style, not the "rope" style.
2 sets. Have the Y-pipe, actuator, tubes, etc.....
The actuator (like so many of them) will only hold for about :45 seconds before it starts fading back to thru-hull.
Would like to sell it all as a set.
In decent shape. Could probably use a thorough polishing and does have some light surface scratches. I have a couple extra bushings as well that go in the turndown rod.
1500 + shipping for everything.
Attached Thumbnails CMI Tails with Silent Choice/Y-Pipes & Actuator-cmi-tail-3.jpg   CMI Tails with Silent Choice/Y-Pipes & Actuator-cmi-tail-4.jpg   CMI Tails with Silent Choice/Y-Pipes & Actuator-cmi-tail-5.jpg
CMI Tails with Silent Choice/Y-Pipes & Actuator-cmi-tail-1%60.jpg   CMI Tails with Silent Choice/Y-Pipes & Actuator-cmi-tail-2.jpg   CMI Tails with Silent Choice/Y-Pipes & Actuator-tail.jpg
seafordguy is offline
Old 11-16-2014 | 12:11 PM
Interested, sent you a pm
Thanks,
Dale
daleroger is offline
Old 11-20-2014 | 10:39 AM
seafordguy's Avatar
Just bringing this back to the top since I've got them in the back seat of the truck. 1,400 for everything shipped.
I will separate the tails / YPIPE / Actuator if anyone wants just certain pieces but would prefer to sell the tails in pairs.
Old 12-17-2014 | 11:09 AM
seafordguy's Avatar
TTT.
Anyone need these?
Old 12-17-2014 | 02:25 PM
bor's Avatar
bor
How much for both y Pipes ?
Shipped to ny11772-3646
bor is offline
Old 12-17-2014 | 08:45 PM
seafordguy's Avatar
Would probably want to wait and see if I sell as a full package.
Old 04-20-2015 | 01:01 PM
seafordguy's Avatar
Back to the top. Getting anxious to order some straight tails and took the Transom Assemblies off yesterday so I have everything in the garage.
Any takers at 1200 for both pairs?
Would consider separating at this stage.....
Old 04-20-2015 | 01:16 PM
I'm interested in this but don't know enough about it... I have CMI headers with 4.5" tips, I believe they are dry to the transom. Any idea if these would work and how they would be installed?
ryan
H2X BOSS is offline
Old 04-20-2015 | 01:53 PM
seafordguy's Avatar
What is the Inside Diameter of your header where it would meet the tail? I believe these are only 4 inch ID where the tail meets. I can measure it when I get home.
What else do you need to know about them? How the Y-Pipe setup works? These are set up as a wet setup. The water flows around the header, up to the top of the header then there is a little jumper tube over to the tail - the water then dumps out into the exhaust at the end of the tail.
Here is the CMI dimensions from the website. I have the standard E-Top headers http://www.custommarine.com/tailpipes/index.php
You can email me if it is easier - eric.ancarrow ( at) ferguson.com
Old 04-24-2015 | 11:00 PM
seafordguy's Avatar
Back to top.....
