HP 500 valve covers.... >
Old 11-03-2014 | 03:10 PM
Default HP 500 valve covers....
Are gen 6 HP500 covers taller than the stock 502mpi covers???
kennyo is offline
Old 11-03-2014 | 03:27 PM
Nope, I believe they're the same cover as the 502mpi except the 500s have expensive blue paint and a really expensive shiny stainless piece with a sticker on it lol.
mickeymcclgn is offline
Old 11-03-2014 | 04:31 PM
F-2 Speedy's Avatar
yup, black =50 bucks blue =200
F-2 Speedy is offline
Old 11-03-2014 | 04:43 PM
some of them had some grinding done on the underside to clear the crane rockers...
ezstriper is offline
Old 11-03-2014 | 05:02 PM
F-2 Speedy's Avatar
I've never seen any valve cover's that have been ground on, but two of the rockers have the corners radiused to clear the hold down boss
Old 11-03-2014 | 08:06 PM
The early blue covers are the silly money , went where mainly stamped covers had dare to go before ,and had to clear those glorious gold rockers lol .then add the stainless sticker on top and you know you have spent some bucks
airjunky is offline
Old 11-04-2014 | 01:54 AM
They are the same valve covers. The black engines have oil drip tabs on the underside. The tabs are ground off on blue engines to clear the roller rocker arms.
Griff is offline
Old 11-04-2014 | 12:48 PM
That's what I thought.... I have a set that won't clear roller rockers with the long studs....Must be different studs from factory.
kennyo is offline
Old 11-04-2014 | 01:18 PM
Agreed! As a matter of fact I installed a set 3 summers ago not thinking of the oil drippers. First rotation the rockers hit them and broke them off. I had to open up the new engine and clean the metal out.
Baja226sport is offline
Old 11-04-2014 | 09:26 PM
Damn I forgot about the ribs under the covers on the gen 5&6 too .
airjunky is offline
