Considering a smaller Baja >
Old 11-03-2014 | 09:20 PM
Default Considering a smaller Baja
I'm considering on getting a smaller Baja. I would like to be able to save more money and go out traveling. Lesser in maintenance and storage cost. Have easier time towing, launching, and retrieving boat by myself. Seeing that I mostly solo boat. I'm looking to stop boating on the Illinois Chain. Instead boat at the Three lakes Chain where it's way less choppier. The Baja 200ss with an I/O. I really like its looks with the metalflake and low profile windshield. What are your opinions of that model?
Quality and comfort?
Top speed?
Captain Nick is offline
Old 11-04-2014 | 07:09 AM
No one ever goes smaller. Time to find a first mate to assist in launching/retrieving
92nsx is offline
Old 11-04-2014 | 07:36 AM
It will feel very small. Depending on where you boat you may hate it if it gets rough.
I doubt you will spend less on maintenance. Its a boat and an older one at that.
Just a few things to consider.
Baja226sport is offline
Old 11-04-2014 | 08:20 AM
25ol is a great size. I launch my 33ol with ease all the time.
If you consider, you will have to do the same process with a smaller boat as you are currently doing.
my process with 25 and now the 33ol.
-Back down ramp til tilting back to get out any water that may have been in it.. Put plug in!
-unstrap and disconnect front tiebar. (boat just sitting on trailer.
-back up boat to just submerge transom but above exhaust and just before it would float. (prevent reversion, been there)
-get out crank, back up and dock.
-move truck.
ENJOY!
Now if you are more worried about saving money... get an smaller outboard boat... Jet ski... ?
I would keep the 25ol especially if your buy yourself... pickup more skanks than with smaller boat :-)
nailit is offline
Old 11-04-2014 | 09:03 AM
Nalit, you are a brave man! I would never take the strap off the bow eye before having the boat in the water. Of course your ramps in LA are probably pretty shallow and ours here are pretty steep.
Now, how do you get the boat back on by yourself? Do you power off and then use the winch alone to pull the boat on the trailer?
Captain Nick - You've got something. A big boat is fun on the water, but a pain everywhere else. A big boat at home on the trailer vs a smaller one you actually use is not much of a choice. I would love a 33OL, but for us it is just not practical from either a cost or logistics perspective. Perhaps that will change some day (and I'm working toward it), but for now...
Dan
BajaDan is offline
Old 11-04-2014 | 10:45 AM
late last summer I sold my 212 Rinker 350mag to my buddy. I had the Rinker and my H2X 24 all last summer and used the Rinker to tow around to different lakes while I kept the H2X in a slip. Frankly I did not like the Rinker all that much compared to the H2X. Running around in the 60mph 212 was fun but I always preferred my bigger 630hp H2X. Now I have bought a Searay 300 w twin 350mags and have to say this new floating condo is pretty nice/ I was going to tow the Baja as a dinghy but that is not working out to well so I have decided to sell my Hotrod H2X. I want $27,500 and yes I know that is a lot for a 98 but it is worth it and I got way more than that in it.
pvan1 is offline
Old 11-04-2014 | 11:13 AM
Sydwayz's Avatar
Forum Regulator
I think the money you will save will be negligible.
Maintenance will be same.
Fuel costs will be slightly less.
Storage costs will be proportionately less.
Solo boating is not a big deal. For the most part, even with help, I do the majority of the work when loading/unloading anyhow. You just need to practice and get a routine.
When launching alone, I back the boat in to where I lower the drive and start it, but it's still attached to the bow stand, and also solid on the trailer. Then go tie two lines to the boat, fore and aft; with enough slack that you can back the truck up another 2-4 feet. Walk up, undo the bow stand winch, and then go back the truck in a hair further. The boat will gently float off, and you can walk back down the pier, snag the slack tied lines, and walk the boat back to the dock to tie it snugly. It can be done with no pier at the launch ramp too. Back the trailer in deep enough that the only thing keeping you attached to the trailer is the bow/stand/winch. Get on the boat, lay prone on the tip of the bow, and disconnect the winch. Then sashay over the cockpit and go drive the boat to where you want to put it while you park the truck.
Retrieving, just walk the boat on the trailer and use the winch. No need to be all gung-ho and drive it on.
If no pier at the ramp, then back the trailer in as such that the bunks will allow you to "land" the boat on the trailer (like beaching it.) Then go up, attach and snug up the winch cable/strap; and back the trailer in a bit more so you can winch it the rest of the way on.
If I can do this with a 37, you can do this with a 25.
Sydwayz is offline
Old 11-04-2014 | 05:42 PM
Dan
The boat isnt floating when I back it down, I also power off and power on. Its funny you say that actually, I have read a lot of threads about complaints about power loading/unloading but I have always done it.
Putting back on, I back down until front bunk has front tip exposed so I can see it, then power load to eye or close enough that I can winch up the rest with a engines in fwd with a little throttle to hold boat.
nailit is offline
Old 11-04-2014 | 05:48 PM
Nailit.....you have no concerns of tearing up props while power loading?
I would say 90% of the ramps in my area have some sort of sand, rocks, or mud where the stern of the boat is.
Old 11-04-2014 | 06:37 PM
I dont bury the drives, they ar prob just above neutral. I dont have to go but maybe 1/2 throttle at most to get it up, the way I have the trailer set up, I have to keep a lil thrust to hold it while I go latch the eye and lock or it will slide back off.
Then as I drive the truck up slooooooooowwwly until the stern sit on the bunks.
nailit is offline
