Cam Questions - Little Help/Direction needed >
Old 11-06-2014 | 04:25 PM
seafordguy's Avatar
Default Cam Questions - Little Help/Direction needed
My boat is going through a refresh this winter. I had some salt water get in my motor through a leaking head (and headers, and headgasket) and am rebuilding. On top of that it has just gotten to the age it needs some attention (new guages, indicator cables, shift cables, TA rebuilds, etc....).
I had one MK IV and one Gen VI in my boat. The IV crapped out on me. Luckily my buddy had a spare VI that he has given me. I am going to refresh the bottom end and then swap my Roller Rockers (Crane 1.7) and Springs onto his motor.
I believe that both of my Cam's are the factory 502 415HP cam. I believe the stock specs are Intake - 211, Exhaust - 227, and if I'm reading this right the lift is only .301?? Not sure of the LSA.
I know this isn't the "right" cam. I run Weiand 177's with the small pulley on them so I can't imagine a cam this mild is the right cam for me.
I guess my real question is can I get by with this cam for a couple years until I am ready to do a full refresh on both motors? The way we use the boat is 75% idle 25% 33-3700RPM cruise. I know I can call Bob M, but I'm not really in a financial position to drop too much money on this rebuild and don't want to tie up his time if I can't afford to work with him.
I might change both cams if Summit/Jegs has something off the shelf that you guys would recommend and I could wake these things up for a couple hundred bucks a motor, but I might also just throw this one back in and go a few seasons - I put about 10 hours on it last season.
Can you guys give me some thoughts/direction?
Thanks,
Eric
seafordguy is offline
Old 11-06-2014 | 05:24 PM
Eric, what size engines are these ?
Stock 502 Mag Cam, is more like 224/224 duration and .483/.483 lift.
MILD THUNDER is offline
Old 11-06-2014 | 05:52 PM
rmbuilder's Avatar
MarineKinetics
Default 415 MPI cam
502 MPI cam
Attached Thumbnails Cam Questions - Little Help/Direction needed-502_mpi.jpg
rmbuilder is offline
Old 11-06-2014 | 05:55 PM
Without a doubt, considering you are running a supercharger, there is alot of power on the table with cam swap and exhaust.
Of course you can run those cams as is, but yes, you are throwing some performance away. Only you are the person that can answer whether or not it's enough power lol
Sometimes you can find some good deals on takeout merc cams here in the swap shop. Even a 500EFI cam would be a big step up from what you have there. But exhaust needs to get installed before any other mods IMO.
Old 11-06-2014 | 05:57 PM
seafordguy's Avatar
They are 502's. The good gen. VI block came from 1800 runs new so I called them and they confirmed the cam specs from the Merc Spec book but I trust you guys more so if those aren't the right specs I'm not totally surprised.....
I was jotting numbers down fast so I am not even sure the .301 lift is accurate, but figured you guys would know the factory specs on the 415hp 502
rmbuilder's Avatar
MarineKinetics
sea.
.300" would be lobe lift
Bob
Old 11-06-2014 | 06:56 PM
SB
Could be anything from Runs New. There have been a lot of problems on multiple forums with there motors.
Just sayin !
And Rmbuilder - good info.
Those .200" numbers of the factory cam are absolutely not getting anything done...are they. LOL.
Obviously everyone with a BBC knows about the non existent lift of this cam.
Seaford guy - here is the skinny plain and simple.
Not only is that cam a lame duck, the GM springs used for this cam are lame also.
So, going to a cam that your motor wants real bad, is going to require more than changing the cam. You are looking at a complete valvetrain overhaul. Cam, springs, pushrods, rockers, and etc,etc.
Doing things on the cheap does not always mean inexpensive.
Doing things on the cheap (in our world) means getting the correct pieces in order, assembling them correctly, and then as far as actual cost, not paying Mercruiser type prices.
This is the beauty of RmBuilder. He knows what pieces are needed and can supply them to you at prices the common working man is comfortable with.
He, like I, don't supply Pixie Dust.
So, if you just have a few hundred to spend, it's going to have to keep the stock cam.
SB is offline
Old 11-06-2014 | 09:43 PM
seafordguy's Avatar
Just sayin !
I am going to check my paperwork tomorrow morning hopefully on the rockers and springs I have. I don't think my springs are GM. I believe they were upgraded along with the crane rockers when the top end refresh was done. I should have clarified that I'm not running GM rockers and I don't believe they are stock springs....
If I can't reuse my rockers and springs then I'll probably just throw it back together as is because I am guessing I am raising my budget significantly. I am under no illusion this could be corrected for a couple hundred dollars but I don't want to get into a couple thousand. If I could get the right cam in them for 1000-1500 then I might have to consider it.
Old 11-06-2014 | 09:46 PM
seafordguy's Avatar
Forum doing funny things for me. Sorry MILD, missed this post. I have CMI headers on them.....
