Gil dry tailpipe
Gil tailpipe, center engine right hand.
4" dry to the tip, fresh water only, pressure tested . like new.
said to have been to Cobra Power for a rebuild with all new parts but that can't be verified.
rumored to have been on a boat don Johnson once parked next to.
this collectors item was lost for years and recently re-discovered in a shipping container that hasn't been opened in a while.
comes with shift plate bracket and a used gasket
fits all boats with the appropriate modifications. tuned for optimum back pressure. dyno sheet was lost along with the installation instructions.
taking offers. shipping available at extra cost.
yea I heard your slip neighbors can barely hear you start up. must be harmonics from all the shag carpeting on N Dock. maybe you should set the idle at about 2200.
so you want this pipe or what? not many of these left, ..................
its what you might call "ideal", but those numbers as you know are kind of a floating target .I was told the guy that set it up was a big deal at Buick in wind tunnel testing but I can't be sure to tell you the truth. This should be good for a cat boat or a v bottom with a pad.
$100 buys it. but if the big boys get into a bidding war..... well who knows. If someone needs this better snap it up.
that's possible, but I am going to stick to just the facts and not get into a lot of guessing.that can get everybody in trouble.. but I will say the low lift scavenging #'s are pretty unreal I had to tape up the ends after the pics because it was sucking dust bunnies off the shop floor and blowing them out all over the place........
$95.00
$95.00
$95.00
$95.00
