Dyno proven 675-700 HP 540CI recipes? >
Old 11-16-2014 | 03:09 PM
Full Force's Avatar
Default Dyno proven 675-700 HP 540CI recipes?
Getting ready to start buying parts soon,I am redoing shortblocks all new 540CI
I have 320CC all redone Pro Comp heads 118CC chambers, not sure flow but told they are comparable to dart and such with 320CC runner
Looking for general cam info and such, where cam was installed RPM max and that, dyno sheets would be cool, tring to get ideas of what to look at for cams, I can get cams I think that seem right up my alley, wanna see what other guys used in that range.
Full Force is offline
Old 11-16-2014 | 03:26 PM
cigrocket's Avatar
My 540s had 741 crane hydraulic cam. I pm'd you the other specs.
680HP Dyno proven and 600 hours of use before a rod failed
cigrocket is offline
Old 11-16-2014 | 03:28 PM
Full Force's Avatar
I tried to reply, your box is full lol
as of now looking at 242/[email protected] 112 LSA .630 lift... I can get 2 used in good shape, made 690 hp with AFR heads.
Old 11-16-2014 | 03:40 PM
Full Force's Avatar
I still cant believe you only got 74 with 680 hp? I am doing 73.5 with only 600 hp now.... I would have thought with 680 like 77-78 or so... TRS
Old 11-17-2014 | 07:13 AM
Which cylinder heads are you using?
88Fountain is offline
Old 11-17-2014 | 07:35 AM
cigrocket's Avatar
This was 3 boats ago, but they were CNC machined AFR heads, port matched.
Konrads were 78 or so
TRS were 74-75
I didn't bother playing with props. 1-2 miles per hour isn't worth the effort. Thousands of more efficient hulls out there if you want top end.
Old 11-17-2014 | 07:42 AM
I would be very cautious with that choice of heads, they like to drop valve seats among other problems. I am sure others will chime in on this.
JRider is offline
Old 11-17-2014 | 08:22 AM
the one place you don,t want to skimp is the cylinder heads.the pro comp heads are pretty much junk.call bob madera ,he can get you a fair deal on AFR cylinder heads.
mike tkach is offline
Old 11-17-2014 | 08:37 AM
Full Force's Avatar
I would not have bought them, they were already on the 600's I bought, last summer I spent so much at Gellner making them right and perfect a few hundred more I could have bought heads, so they have been 100% brought up to par by a good name person. not buying heads after spending what I did on these.... new valves, seats, guides, keepers, retainers, valve job, on ly thing reused was springs since they checked out... EVERYTHING else has been redone.... Tom at GELLNER assured me they are fine now.... before not so much
Old 11-17-2014 | 12:03 PM
PRO-COMP heads.....Ran a few sets on drag car builds and they still dont last, Im willing to bet there will be a post next year on how the engines dont make as much HP as they should, keeps blowing head gaskets, cant get rocker geometry correct, etc..... but suit yourself its your money. Just my experience.
Cobra100+ is offline
