Oil Pan repair
Pulled the hurt motor out of the Velocity 280 i bought. while the engine is being built i figured i would clean up and spray the valve covers and oil pan that was on the old motor to re-use. the oil pan is a teague 10qt by the looks of it. i found a small crack, around 2" long in the bottom . i assume the genius who built and installed this motor probably set it on the pan. explains the milkshake oil after the first run. probably taking in water from the bilge. my question is, would it be safe to weld and grind this oil pan? i hate to shell out $700 on a new one. i'm no stranger to metal work, and i don't see it being an issue really... just curious
I'm still trying to play detective to figure out exactly what happened with this motor. My blocked was cracked in the two rear banks, it hydrolocked, all cylinders were full of water when i pulled the heads and there was water in the pan as well as mixed with the oil. All i'm keeping is the intake, pan, and valve covers. Starting fresh instead of chasing someone elses mistakes
all cyl full sounds like exhausts. iron heads in salt? they rot at the valve guides but usually only 1 or 2 cyls will fail that bad at same time. i wouldn't scrap the block out of hand. they are the toughest part unless it froze. but no way did water come in from a crack in bottom of pan unless lots of oil leaked out. pour some acetone into pan. if it doesn't run out, water didn't run in.
this boat is new to me, so i'm just tossing the whole thing and doing it right the first time. fresh gen 6 block, forged 496 stroker rotating assembly, gonna contact Bob M for a cam grind, new Brodix heads, new holley 850 carb... i pressure tested my dana products exhaust and it seems fine.
this boat is new to me, so i'm just tossing the whole thing and doing it right the first time. fresh gen 6 block, forged 496 rotating assembly, gonna contact Bob M for a cam grind, new Brodix heads, new holley 850 carb... i pressure tested my dana products exhaust and it seems fine.
