89 Formula 357 Restoration >
Old 11-17-2014 | 08:21 PM
JCCRAZY's Avatar
Default 89 Formula 357 Restoration
I have always liked the larger SR1 designs. I finally had the opportunity to buy one that had low hours and was a solid candidate to restore. It is painted with a true candy apple design and, in most opinions, looks amazing in the sunshine. After many months of work it's coming to completion. It has been updated to Bravo drives and what should be "relatively" efficient high torque engines. It has been designed for solid fast cruising and a comfortable ride in rough waters with upgraded 380 k-planes. It will be finished with a new aluminum swim platform and Stainless Marine long risers. Any comments or suggestions are welcome.[ATTACH=CONFIG]532773[/ATTACH][ATTACH=CONFIG]532774[/ATTACH][ATTACH=CONFIG]532775[/ATTACH][ATTACH=CONFIG]532776[/ATTACH][ATTACH=CONFIG]532777[/ATTACH][ATTACH=CONFIG]532778[/ATTACH][ATTACH=CONFIG]532779[/ATTACH][ATTACH=CONFIG]532780[/ATTACH][ATTACH=CONFIG]532781[/ATTACH][ATTACH=CONFIG]532773[/ATTACH][ATTACH=CONFIG]532774[/ATTACH][ATTACH=CONFIG]532775[/ATTACH][ATTACH=CONFIG]532776[/ATTACH][ATTACH=CONFIG]532777[/ATTACH][ATTACH=CONFIG]532778[/ATTACH][ATTACH=CONFIG]532779[/ATTACH][ATTACH=CONFIG]532780[/ATTACH][ATTACH=CONFIG]532781[/ATTACH]
Attached Thumbnails 89 Formula 357 Restoration-image.jpg   89 Formula 357 Restoration-image.jpg   89 Formula 357 Restoration-image.jpg
JCCRAZY is offline
Old 11-17-2014 | 09:01 PM
jeff32's Avatar
Ron sporl had it listed for 25k right?
Looks like a nice clean boat for sure! I had two of these, one i restored! Heavy pig but tons of room!
jeff32 is offline
Old 11-17-2014 | 09:09 PM
jeff32's Avatar
What engines are you gonna use?
jeff32 is offline
Old 11-17-2014 | 09:13 PM
Beautiful man!! Great job!!
Crude Intentions is offline
Old 11-17-2014 | 09:20 PM
jeff32's Avatar
For some reason my last post did not appear as the last post...
So? Engines?
jeff32 is offline
JCCRAZY's Avatar
Yes I purchased the hull and trailer from Ron. Very nice guy and well worth the trip to pick it up. The engines that were originally built for this boat are outrageous 632's and are still for sale in classifieds I think. Unfortunately they weren't in the original budget.
JCCRAZY is offline
jeff32's Avatar
So? Engines?
jeff32 is offline
Old 11-17-2014 | 09:50 PM
JCCRAZY's Avatar
I'm using 468's with 420 based bottom ends and custom head and cam set ups. HP in the 480 range but torque is closer to 550 and should be quite durable. They were built by Speed n Sport.
JCCRAZY is offline
Old 11-17-2014 | 10:39 PM
JCCRAZY's Avatar
The boat will never compete with most of the modern set ups for top speed but it's a good ride in rough seas and shouldn't break the bank, although the restoration has been a long and not inexpensive road.
JCCRAZY is offline
Old 11-18-2014 | 12:04 AM
Looks great, I'm sure you'll enjoy it.
payuppsucker is offline
