Hard time filling fuel tank >
Old 11-19-2014 | 07:17 AM
Default Hard time filling fuel tank
My 27' does not like taking gas at the pump for some reason. Every time I fill it up, I always end up with fuel all over me, the boat, and the ground. Fuel blows back out of the fill port and the vent line constantly. I have to barely squeeze the handle on the nozzle and hold it so that nozzle is just inside of the filler neck. Doing that helps, but it also takes forever to put 40 or 50 gallons in the boat this way. Anyone else have this problem or have any suggestions on what I can do to fix it ? I have considered running another vent line off of the tank to possibly let the air escape more easily. Any thoughts ?
highball is offline
Old 11-19-2014 | 08:03 AM
It has to do with the fact that sitting on a trailer the vent and fill necks become covered with fuel and won't allow proper air evacuation as you fill. They take gas much better sitting in the water. I have a good friend that will sometimes unhitch his and jack the trailer sky high in the front when fueling and it helps.
Jpzaluski is offline
Old 11-19-2014 | 08:27 AM
That makes sense. So there's no real way to solve it without tank modifications ?
highball is offline
Old 11-19-2014 | 09:46 AM
On Time's Avatar
I had some success with a fairly stiff 1/2" plastic tube down the filler neck to the tank. It needs to curl back up into the air space. My 33 Baja was terrible with this problem. For some reason my 42 Fountain is not.
On Time is offline
Old 11-19-2014 | 10:25 AM
SB
Yup. Gas is either in your vent or getting in your vent. Sounds to me, as mentioned above, your vent is not at an air space in your tank when filling. May need to raise/lower boat angle when getting gas.
Always make sure the vent is not restricted by debris/insects and that there are no sharp kinks in vent line too.
Edit in: Read post below by 79 Formula. Have run into this with several boats....and not just older boats !
SB is offline
Old 11-19-2014 | 10:55 AM
I had the same problem with my Formula. Turned out the fuel fill hose had sagged on one spot, acting like a P-Trap on a sink. I put another strap on the hose so it couldn't sag there, problem solved. Drove me nuts for 2 years, It was only drooped about 1 inch too.
79formula is offline
Old 11-19-2014 | 01:01 PM
Thanks for the advice guys.
highball is offline
Old 11-19-2014 | 01:32 PM
SB
Highball - I also had a boat where the fuel fill hose and vent line followed the floor for a few feet. These being horizontal would obviously also trap fuel. I put a downward slope on them and it took care of them. Many times, riggers of new boats do things without always thinking of the consequences of when in use.
Like I say in my shop alot when someone asks why a manufacturer or another repair shop does a certain thing " Well, there was a reason for it, however it's not always a good reason."
SB is offline
Old 11-19-2014 | 03:07 PM
I've got to change my drive oil this weekend, so that will give me a chance to look into some of the ideas that y'all have given me.
highball is offline
Old 11-19-2014 | 03:43 PM
Spiders tend to clog the vent outlets. I clean mine 3-4 a season.
Interceptor is offline
