High & Dry Storage
Thinking of placing the boat next season at a marina (high &dry) storage. Anyone doing this presently with 353 Fastech? Hoping someone could give me their insight on this.
Thanks,
Chris
Thanks,
Chris
My biggest concern is the bottom getting messed up. I do understand that if I (spoil) the forklift operators to take extra care that always goes a long way but are there any significant concerns I need to watch out for? Is it a good idea for me to build the racks myself to fit the hull properly? Was told they would let me do that.
Thanks for the insight.
Chris
Chris
Chris
Chris
As for the cradle support, its always best to support the hull in the right places, so if you have the option of constructing a cradle that's tailored to your hull and supports the critical spots (like a trailer would), and you have the skill to do so, why wouldn't you do that??
When you're boat is in the steel rack, it will actually be resting on a wooden cradle mounted to the steel rack. The cradle is not the issue; it's the forks that cause the marks on the bottom. The whole issue with the forks is based on the condition of the protective rubber on the forks themselves. If your marina maintains their equipment well, this should be a non-issue. The skill of the fork truck operator is more important. I had one day, my guy lifted my boat and the tip of the fork caught the bottom of the step and chipped about an inch of gelcoat off.. not happy.. but they fixed it and you couldn't tell it ever happened.
