Tell me about SSM drives.
Old 11-20-2014 | 08:08 PM
Default Tell me about SSM drives.
Need some info on older SSM. no 3 drives. How much ponies can they handle? Reliability. maintenance. etc. pros and cons.
THx
P
PARADOX is offline
Old 11-20-2014 | 08:29 PM
phughes69's Avatar
I'll start I think a good reliable HP number is between 650-750
phughes69 is offline
Old 11-20-2014 | 08:47 PM
I've heard 650 ft/lbs thrown around for the SSM #3. BAM lists the beefed up 3A as rated for 750hp/750tq.
Pros and cons.... Guess those depend on what drive you are comparing them to.
Speedracer29 is offline
Old 11-20-2014 | 10:46 PM
Gladhe8er's Avatar
Aren't 3's the ones that are really hard to get parts for?
Gladhe8er is offline
Old 11-20-2014 | 10:59 PM
northernoffshore's Avatar
both these boats had 800 + hp and never a problem
northernoffshore is offline
Old 11-21-2014 | 07:55 AM
Planning to push 580 HP on each, so I think it should be ok. Any issues with the Merc transmissions that were used with them?
PARADOX is offline
Old 11-21-2014 | 08:03 AM
they are a great upgrade to a bravo xr. you should be just fine with 750 hp. the boat will shift nicely with a trans. and there are still guys out there that can repair them. i believe it will add value to your boat as well. it gives me piece of mind knowing that i have speedmasters on the rear of my boat
cig92 is offline
Old 11-21-2014 | 08:07 AM
Plan your drive height and prop selection ahead of time. At 600hp @ 6000 rpm, and a drive height of. 3" below the bottom, my prop selection was very limited. Needed 16 3/4" diameter min to get on plane, with about 23-24" of pitch. 600 hp was not enough to spin the props. So if your going with 580hp, keep the drives a little low so you can run a more common 16-16.5" prop with 23" pitch.
Unlimited jd is offline
Old 11-21-2014 | 03:17 PM
RMPRam's Avatar
There are still new internal parts available for the #3 drive. I have new 1.31:1 straight cut, net forged upper gear sets ( the same "gear" as used in the #3A and the #5 drives, but manufactured with the "shank" as I call it, to be used in a #3 drive ) and new 1.75" dia.propshafts available for these drives. These pieces were manufactured in the USA. I can also supply the same upper gear that has a "polygon" internal for the #4 drive.
Gary
612-247-7081
RMPRam is offline
Old 11-23-2014 | 07:17 AM
THanks for the info and PM's. Not looking for any parts or to buy just yet, just some info.
P
PARADOX is offline
