Missing skeg(s) and cavitation plate
So my new to me formula 242 has some damage to the drives, both skegs are flat about 2 inches below the prop, they are ground even and painted to match the drive so I'm guessing they have been run like that for a long time. Also on the starboard motor (twin 260 hp with alpha 1) there's a corner missing from the cavitation plate. I've only had the boat out once, it ran up to 58 mph with a fuel tank of fuel so I don't know if the plate is a big deal the wake and rooster tail didn't look strange, and that motor actually feels stronger then the other. The boat felt super light and sketchy though at that speed I'm wondering if the skegs are part of that. Anybody used one of the glue on fins to repair for the skegs? Saw some in carbon look cool but I can't see any need for carbon there. What about the cavitation plate worry or not? I'm sure I can find someone to come weld a corner if that's what I need
I can tell you this much.... My skeg was looking a little haggard... I bought a replacement merc skeg, paid a guy with a good rep for fixing skegs to weld it on. It came off within 10 minutes, folded back into the prop, destroyed a stainless prop. bent the prop shaft, took a big chunk out of the cavitation plate and put a few cracks in the lower housing. So basically my entire bravo lower is a paperweight
Be carefull what and how you chose to fix something...
New drives would be nice but not in the budget right now. there's plenty of boat toys that could eat that 1700.00.
I don't know how high they were trimmed up, the trim gauges aren't accurate. The rpm went up and I stopped.
