Closed cooling 454 with 496 manifolds help >
Old 11-22-2014 | 05:58 PM
Default Closed cooling 454 with 496 manifolds help
I am putting 496 exhaust exhaust manifolds on a closed cooling 454 and need some information on plumbing the cooling system. I know guys on OSO have done this mod and was wondering how they plumbed the cooling system to there manifolds. I don't have to worry about the oil filter or any linkage just the plumbing, any thoughts or suggestions are appreciated Jamie
jamie 10017 is offline
Old 11-22-2014 | 06:14 PM
GOOGLED "mercruiser closed cooling system diagram" AND CAME UP WITH MULTIPLE DIAGRAMS
GLENAMY 242SS is offline
Old 11-23-2014 | 07:00 AM
Ayuh,..... Do ya have heat exchanger enough to include the exhaust manifolds into the freshwater side,..??
Bondo is offline
Old 11-24-2014 | 06:13 AM
personally i feel you should just closed cool the engine and leave exhaust manifolds raw water. although all my experience is with wet joint stock style stuff. the manifold to riser block-off is where the most leakage problems arise. but those gil 496 manifolds being dry joint might not be such an issue. but plumbing is a lot simpler with running the exhausts raw water.
dereknkathy is offline
Old 11-24-2014 | 07:40 AM
I have aluminum 496 exhaust on my 502 and it was a pretty easy install..... I only used 1 of the 2 riser water inputs and it provides plenty of cooling....... I am in salt water using lots of aluminum engine components so closed cooling is a no brainer..... You will like the results.... Go for it!
tpabayflyer is offline
Old 11-24-2014 | 07:42 AM
I used the monitor products system and you can go on their website for a detailed diagram of the installation.....
Old 11-24-2014 | 01:41 PM
Did you use both water outlets of the manifold or did you also block one of manifold water outlets ?
Andre
5andree is offline
Old 11-30-2014 | 09:49 AM
Also just one....... I have never see more than 180* even running hard in the florida heat!
Old 07-20-2015 | 08:59 PM
How the heck did you block off the outlets!!!!? I have been searching for stuff for the last week and can't find anything. . I'm trying to run it like you did .. I had ran both hoses coming from the thermostat housing to the lower side of the manifold but while testing it started to overheat..
Please help
Thanks !
itpro2000 is offline
