Small Block Chevy MArine Kenetics Cam - Hyd Roller
Custom Bob Madura/Marine Kinetics-spec/Cam Motion hydraulic roller for pre-87 sbc. I used this in the 383 that was in my Stinger. This cam is on a small base circle billet-steel core (not iron junk). Very little run time. Will need good exhaust (my tailpipes dumped water just prior to the tips).
Spec sheet included.
Specs:
Cam Motion Billet Core
LSA 112.2 deg
Overlap 16.3 deg
Intake
VO: 11.2 BTDC
Centerline: 108.2 ATDC
VC: 47.2 ABDC
Duration: 238.7 @ .050
Lobe Lift: .38012"
Valve Lift: .57018" w/1.5 rocker
Exhaust
VO: 57.2 deg BBDC
Centerline: 116.2 BTDC
VC: 5.1 deg ATDC
Duration: 242.3 @ .050
Lobe Lift: .37091"
Valve Lift: .55636"
This was a very aggressive cam in my 383. Lots of top end power and an explosive midrange. Perfect match for a set of 200cc heads.
Asking $350 plus the ride.
Specs:
LSA 112.2 deg
Overlap 16.3 deg
Intake
VO: 11.2 BTDC
VC: 47.2 ABDC
Lobe Lift: .38012"
Exhaust
VO: 57.2 deg BBDC
VC: 5.1 deg ATDC
Lobe Lift: .37091"
Valve Lift: .55636"
