Smart Craft VesselView Question >
Old 11-24-2014 | 06:51 PM
Default Smart Craft VesselView Question
Does anyone know how to program the VesselView to recognize the third engine? I can't seem to figure it out
PremierPOWER is offline
Old 11-24-2014 | 06:52 PM
Here is a picture
[ATTACH=CONFIG]533141[/ATTACH]
Old 11-24-2014 | 07:38 PM
I have Smartcraft but it's pretty dumb. or is it me? GO to the Mercury racing website and download the manual. It will tell you.
PARADOX is offline
Old 11-25-2014 | 09:53 AM
I've done a factory restart and still isn't recognizing it. My only thought is one of the connections on center engine is loose?
Old 11-25-2014 | 10:02 AM
Download the manual. YOu have to "answer" how many motors you got some place.
PARADOX is offline
Old 11-25-2014 | 10:55 AM
You may have a bad connection somewhere. I would start by connecting a Mercury CDS to each engine and set the engine location.
Since it's a triple, you will have to label them as:
Port - Port Outside
Center - Stbd Inside ( It will show physically show as center engine on the vessel view when completed )
Stbd - Stbd Outside
Then Perform a Vessel View factory default reset.
Select as triple engine, and follow all prompts and calibrate as needed ( tanks / tabs if needed )
Hope this helps
Alan Gordon
Service Manager
[email protected]
TeamShogren.com is offline
Old 11-25-2014 | 03:35 PM
Like Alan said. If the center motor is a right hand rotation the computer comes from the factory set to stbd. It will have to be changed with a Mercury computer. Once they are all set up properly there is a setting in the vessel/raceview also for multiple engines.
Double Rigged is offline
Old 11-25-2014 | 08:02 PM
How can we purchase the Mercury CDS software?
Old 11-26-2014 | 09:16 AM
I'm not exactly sure on where to purchase without being a dealer. However if you are near any Mercruiser dealers - chances are they have a CDS and you could have them program for you. It should take them no more than 30 minutes to complete.
Alan Gordon
Service Manager
[email protected]
847-336-9037
Old 11-26-2014 | 10:40 PM
A rinda scan tool can program that for you also. Cost about $400.
BTW, what boat and what tripps are you working on? Just curious.
turbo rr is offline
