determining the right pitch
hey guys I am looking for a little help in determining what pitch props I want to try maybe this summer to try to get alittle more top end. I am currently running 500 EFI motors with stock 28 pitch Bravo ones.I get upper 70s on gps all day at around 51-5200 rpms. The best I have seen was 82 in a good chop on gps but only seen that once. Would a set of 30s get me up over the 80s mark more? I also thought about labing my 28s but seems to be about the same price of a nice set of 30s on here. What u guys think.
With 30's your only going to rev 4800-4900 rpms. Where's your rev limiter set at? Labbing your 28's will add a couple hundred rpms if you have room under the limiter. Will also be harder to plane with the 30's and be more sluggish all around. I'm going through the same thing with 30's and 32's. 28 five blades may be an option for you as well.
Trying "so called" 30 pitch props on here is a some times a slippery slope.
Let me know any questions I can help with.
Brett
[email protected]
[email protected]
We / Mercury Marine came out with these square bore hub assemblies in around 1998. This has been the standard in the industry since. The beauty is they can be used on various engine manufacturer engines besides Mercury and can be replaced by the consumer rather than only by a prop shop if the plastic insert is used and happens to break.
Brett
Brett
[email protected]
[email protected]
