valve spring bearing >
Old 11-30-2014 | 04:37 PM
Default valve spring bearing
In some coil spring apps a thrust bearing is placed under one side of the coil to reduce friction and you end up with a more efficient combo.
Has this ever been tried with valve springs? Slap me if I'm waaaay off in left field.
Cole2534 is offline
Old 11-30-2014 | 05:48 PM
I have never seen a thrust bearing used on a coil spring... What application?
Black Baja is offline
Old 11-30-2014 | 06:13 PM
Rotators on old exhaust valve springs, that's all I've seen. Although I swear I did actually see one hack shop put them on the intake valves. Maybe he trained at cobra?
Unlimited jd is offline
Old 11-30-2014 | 06:49 PM
There's a BBC head that uses rotator on both intake and exhaust valves
sutphen 30 is online now
Old 11-30-2014 | 06:50 PM
I've seen them on coil overs
On the fronts
Old 11-30-2014 | 07:05 PM
SB
Under clutch springs for snowmobiles...LOL. But that's because these springs twisting/turning is part of the force used to tune the clutch. These clutches twist open and close.
BTW: Valves/springs/etc rotate without rotators/bearings/etc.
http://www.youtube.com/watch?v=WtqDHJDN79w&feature=player_embedded
SB is offline
Old 11-30-2014 | 07:09 PM
SB
Struts. Front ones.
SB is offline
Old 11-30-2014 | 07:35 PM
Originally Posted by SB
Struts. Front ones.
I understand very well they use a bearing on top of front struts so the car can turn. But that's not what I got out of his description of a thrust bearing on the coil spring.
Old 11-30-2014 | 07:37 PM
Haven't run across it but his was a sbc, one head they were on the exhaust, the other on the intakes.
SB
Oh, I thought you took valvespring and brought in coil springs in general. My bad.
If you did mean coil springs in general, then I'll remain with my snowmobile clutch examples as others and I (in some clutches) use bearings in direct contact with the coil spring.
SB is offline
