Complete ready to run engine 1071 blower 502 BBC pumpgas
Here is a Complete engine, fresh rebuild still on the Dyno cart.
The engine was built buy Garry Grimes twister engines out of Atlanta Ga (he builds MANY successful offshore engines)
It is a 502 big block chevy Intake to oilpan, with distributer and fuel pump.
-Forged GM crank
-Forged arp 7/16 bolt rods
-JE pistons
-Ported Iron heads
-GM 4 bolt heavy duty block
-Comp cams custom grind cam with stud girdle, roller rockers ect.
-B&M megablower 420 (based on research a good blower that falls between a 6-71 and 8-71 size, based on B&M's own design that has supported up to 1000hp depending on the engine used)
-Air/water aftercooler
-Demon carbs jetted and tuned on the dyno
-8.5:1 compression setup for 93 octane
Dynoed 705 hp (very mild for pumpgas can easily support more)
Good reliable engine that just has dyno time after being refreshened. $8500 complete ready to run.
Call with any more specifics, we changed over to cars and turbo smallblocks so we are selling the boat parts. I can also get you into contact with the engine builder as well for any more questions.
Thanks! Sam D. 423 605 2083 The engine is located in Chattanooga TN.
-Forged GM crank
-JE pistons
-Ported Iron heads
-Forged GM crank
-JE pistons
-Ported Iron heads
-Edelbrock 10-71 megablower
Dynoed 705 hp
-Forged GM crank
-JE pistons
-Ported Iron heads
Dynoed 705 hp
I would like to sell complete. I have it priced for a pretty good deal for someone. We are trying to work with grimes on the 4v mercury Lsx heads on a hotrod setup so hopefully this puts a small dent in that project hahaha.
feel free to text or email as well [email protected]
[/IMG]
[/IMG]
