bilge cleaner? >
bilge cleaner?
bilge cleaner?
Old 08-31-2002 | 01:59 PM
Default bilge cleaner?
Wondering if I can use bilge cleaner to clean the engine compartment on my jetskies? Any ideas on how to do this? Thanks in advance, 88 Mach 1
88 MACH 1 is offline
Old 09-01-2002 | 12:14 AM
Try this stuff. It worked on bilge and did not harm the components. It's worth every cent
Vyper340 is offline
Old 09-01-2002 | 02:10 PM
Ted G's Avatar
Bilge cleaner or Spray nine has always worked for my Doo!
www.cbpba.com
Ted G is offline
Old 09-01-2002 | 02:25 PM
ONly problem I can see is that I do not have a drain plug. Do these bilge cleaners need to be hosed off?
Old 09-01-2002 | 03:12 PM
Ted G's Avatar
Default Get out a drill!
yup
www.cbpba.com
Ted G is offline
Old 09-01-2002 | 05:08 PM
NO DRILL.........Don't be silly........LMAO. OK then I guess I'll have to spray it down then rinse while it's on it's side. Thanks, 88 MACH1
Old 09-02-2002 | 10:39 PM
mcollinstn's Avatar
Are you sure yo udon't have drainplugs in your ski?
If not, go get the entire Yamaha drain assy. It is the easiest one to retrofit. Drill 3 holes, squirt some 3M 5200 on it and screw the assy into place. Now you have drain plugs.
mcollinstn is offline
nova26
05-20-2008 09:04 AM
gsmith9898
2
07-12-2007 08:25 AM
justice
Cigarette
7
01-31-2007 03:55 PM
Sea-Dated
8
09-22-2006 12:17 PM
Prater
04-21-2006 05:39 PM
