What is CHEVY AUTO RIDE ????? >
Old 08-31-2002 | 02:47 PM
bobby daniels
Question What is CHEVY AUTO RIDE ?????
WHAT OR BETTER YET HOW DOES AUTO RIDE WORK ON LATE MODEL 3/4 TON SUBURBANS DOES ANYONE KNOW ?
I'VE LOOKED AT THE SHOCKS AND SEE NO WIRING OR TUBING SO HOW DOES IT CONTROL THE RIDE ??
THANKS FOR THE HELP
Old 08-31-2002 | 03:09 PM
chrker's Avatar
Good question. On GM's website, this is all I could find:
Q: My vehicle says it has "Autoride." What is this and what does it do?
A: Autoride is a fully automatic system that uses a computer controller and sensors to provide superior vehicle ride and handling under a variety of conditions. The controller monitors vehicle speed, wheel to body position, lift/dive and steering position and sends signals to each shock absorber, independently to provide the optimum ride. Part of this feature is automatic level control, which maintains the proper vehicle height on the rear of your vehicle under a variety of loading conditions. You may hear the air compressor running or the system exhausting air to adjust height when the ignition is turned to on, and for up to ten minutes after it has been turned off. Autoride also interacts with the Tow/Haul mode switch to provide additional control when towing a trailer.
But without wires or tubing, exactly how does it work? Osmosis?
-Chris
chrker is offline
Old 08-31-2002 | 03:14 PM
bobby daniels
THANKS CHRIS ! I'M JUST TRYING TO UNDERSTAND THE FEATURE
WITH OUT WIRING IT TOUGH ?????
THANKS FOR THE COMMENT
Old 08-31-2002 | 04:31 PM
bobby daniels
Talking
THANKS ,THAT WAS VERY HELPFUL AND NOW I FEEL STUPIDER THAN NORMAL !
MY 8100/2001/SUBURBAN 3/4 TON,4X4,IS A GREAT TRUCK IT JUST RIDES TO MUCH LIKE ONE ! MAYBE THE COMPUTER IS BROKEN OR I'M GETTING OLDER ! OR BOTH I NOTICE WHEN I TURN THE TRUCK OFF THE REAR IS UP AND DRIVING IT IS LEVEL .I WONDER IS THERE ANYWAY TO ADJUST THIS SYSTEM ALSO ITS TOUGH TOWING A 11K POUND BOAT AS THE REAR MOVES AROUND ALOT EVEN IN TOW HAUL MODE
THANKS VERY MUCH FOR THE TIME HELPING ME !!
Old 08-31-2002 | 06:53 PM
bobby daniels
I'M RUNNING MICHELIN, 275/70/R16'S AND THEY ARE E LOAD RANGE, WHAT TYPE OF TIRE ARE YOU RUNNING? AND BY THE WAY DOES YOURS KNOCK WHEN YOU FIRST START IT.
THANK YOU FOR YOUR TIME AND HELP
Old 08-31-2002 | 10:06 PM
bobby daniels
THANKS FOR ALL THE HELP AND HAVE A GREAT HOLIDAY
ThirdBird
13
05-17-2007 11:07 AM
wrinkleface
2
12-15-2006 08:20 PM
icanread
09-03-2006 11:15 AM
bobby daniels
07-14-2003 11:40 PM
