Latham Full to Helm Twin Bravo Hydraulic Steering >
Old 12-10-2014 | 07:43 PM
$3,500 Or Best Offer
Full kit off ~35' boat with LMD7 Helm and Bravo Brackets
This kit has roughly $1,000 worth of extras that you might not normally find in other kits on the market including:
-Power steering pump (I was told higher pressure but cannot verify) with the top welded shut/modified for external reservoir (v-belt)
-Twin tie bars with a pair of saddles (37" and 33 1/2" or so measured from center of pins)
-IMCO twin pump valve; part # PT13 on Page 63/126 in this IMCO catalog.
-2 Extra power steering reservoir caps (one of which you will need to utilize the twin pump setup, use both if you utilize your existing pump and not the one included)
NOTES:
-No steering wheel or wheel hub included.
-You will need drive studs for for these caps, they are not included.
-You will need a few extra lines to utilize the IMCO twin pump valve, and another banjo fitting for your other pump.
-I cannot guarantee the length of these lines will work with your boat, shorting or adding extensions is inexpensive.
-Shipping will be from Maryland, I would guess 100$ or so to ship to USA.
Thanks for Looking!
Happy Holidays
Jordan is offline
Old 12-15-2014 | 08:05 PM
Price is negotiable, thanks. I will also sell it without the extras.
Jordan is offline
Old 12-22-2014 | 12:09 PM
Ttt
Jordan is offline
Old 12-28-2014 | 09:42 PM
Hi
I maybe interested in the full set up minus the tiebars and the wing plates.
I am looking for a set up for a bpm centre rudder on an old class 1 race cat.
I will PM you
Mat
mat h is offline
Old 01-07-2015 | 10:39 AM
Bump
Jordan is offline
Old 03-21-2015 | 08:42 AM
Still available ?
poiuy10 is offline
Old 03-21-2015 | 08:45 AM
It is, in no rush to sell may just keep it around for next project.
Jordan is offline
Old 03-25-2015 | 08:09 PM
Are the tie bars forsale alone? im looking for one 36 7/8 inch center.
chevytruckman is offline
Old 03-26-2015 | 10:39 AM
How much for the working system, without the extras ? I just need basic system to run off my stock pump. Twin Bravos on 34 " center.
Thanks,
Dale
daleroger is offline
Old 03-27-2015 | 08:48 AM
I have the bar you need, I need to make sure it's not the bar that I need for the kit. Will get back to you!
Jordan is offline
