Regular or Swept back >
Old 12-15-2014 | 07:58 AM
Default Regular or Swept back
What's the difference between the Bravo old style and swept back XR style drives. Is it internals or just outer appearance?
AllDodge is offline
Old 12-15-2014 | 04:29 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Both internal and cosmetic differences .
the deep is offline
Old 12-15-2014 | 05:07 PM
Agreed, little inside, little out.
One thing stays the same, real power will trash them both.
In the end, same old, same old!
RaggedEdge is offline
Old 12-15-2014 | 06:02 PM
the deep's Avatar
Fast Singles Club
If by chance you meant is there a diff between the XR and the XR Sweptback the answer is only cosmetic diff between the two .
the deep is offline
Old 12-15-2014 | 06:12 PM
The insides are identical. The exterior is different. I have pondered whether the sweptback adds structural stiffness but I doubt it....
The swept backs are prettier - IMHO. As RE stated, they all break if you throw more than 501 horsepower at them or your prop comes out of the water more than once.
Keith Atlanta is offline
Old 12-15-2014 | 06:19 PM
Just curious, would an xr bolt to a standard bravo hp gimbal? Or are the spline count, shafts different than a standard b1?
ham_r_down01 is offline
Old 12-15-2014 | 06:30 PM
They fit. Same helmet bolt pattern, same splines.
Old 12-15-2014 | 06:31 PM
It will bolt up just need the later syle gimble bearing to clear the larger u joints. The bearings inner race is shorter on the drive side.
Donzi1979 is offline
Old 12-16-2014 | 07:26 AM
Thanks appreciate the info. Still haven't chosen which drive ratio I'm going with on my repower, good to know it's just looks, which I do like the new style
AllDodge is offline
Old 12-16-2014 | 02:09 PM
they claim more upper support for the bearing...
ezstriper is offline
