Truck mileage verification
Old 12-16-2014 | 05:07 PM
Default Truck mileage verification
Can anyone help me locate a site to verify mileage on a 08 GMC dually, besides Carfax ($39.95)
Thks
boatsbywheels is offline
Old 12-16-2014 | 05:09 PM
Anybody with a computer scan tool can read it.
Jonesyfxr is offline
Old 12-16-2014 | 08:12 PM
A basic scan tool will not read it. You will need a tech 2 or other more powerful scan tool to do it. What is the vin I will run an auto check for you.
82predictor is offline
Old 12-16-2014 | 10:01 PM
^^ +1 and even then if their were ever a problem with the cluster which gm is known for and with the rite software you could tell the company that ththeir was what ever miles on it..
FIXX is offline
Old 12-16-2014 | 10:19 PM
If anyone local needs their GM cluster fixed we can do most of them (gauges/lights/odometer)
Old 12-17-2014 | 05:37 AM
This is what I meant. Sorry
Old 12-17-2014 | 08:01 AM
Actually that is not correct. .miles are recorded on most modules on gm cars..sir..abs..tcm..ecm..bcm..just to name a few.you change the miles on the IPC and all I have to do is hook up my tech 2 and could tell you the real miles.
boatnt is online now
Old 12-17-2014 | 06:26 PM
so you can put what ever milage on the cluster..chrysler with the drb i can put what ever milage on the cluster and same goes with ford ..i have seen my buddy swap clusters on his ford truck and it shower the same milage that was on it in the other truck..just sayin..
FIXX is offline
Old 12-17-2014 | 06:42 PM
yes you can put what ever mileage you want on the cluster,every time we replace a IPC (cluster) we have to program and set up,at that time we put in the miles, we also have to put in the correct hours as well,we can at that time program the IPC with what ever miles and hours we want,,(we always put in the correct miles)..
if somebody "accidentally" programs the wrong miles on the IPC ,next time it goes to a dealership and a Tech scans the data with his/hers Tech 2 or GDS2 the miles of the IPC (cluster) will NOT match the miles recorded on the other modules,like the BCM,SDM,ECM,EBCM just name a few.
Old 12-17-2014 | 07:21 PM
Thks much 08 GMC #1GTJC33618F122341
