Trs swivel pins
Pirate of the Chesapeake
How the Hell do you get that bottom swivel pin out of a TRS transom assembley.Or the tilt pins I have the tool for the tilt pins but can't get them to budge/ HELP
Cut the bellows out to get it out of your way. Your going to replace it anyway. Hing pins thread into the bell housing so heat them on the inside of the bell housing to loosen the Loctite. Make sure they become loose enough to remove and you aren't just using excessive force. You can pull the threads right out of the bell if not carefull. With bell housing removed you should be able to knock the lower swivel pin out.
