ITS on a 2004 29 Fountain 525/XR >
Old 12-27-2014 | 10:45 AM
Default ITS on a 2004 29 Fountain 525/XR
Was looking for a spare XR and found a nice one with a complete ITS so bought. Now trying to decide if it will add anything to a 2004 with a 19.5 X dimension. Anybody out there run one?
papps is offline
Old 12-27-2014 | 11:37 AM
More info......
Standard factory boat with external steering and kplanes. Runs mid 70's with bravo 28p RH prop at about 5200-5300 rpm. Looking for better planing and midrange if I were to make this change.
papps is offline
Old 01-03-2015 | 12:12 PM
Change to 26" B1 prop. Much better planning and you will run 77-78 all day long at 5400 rpms.
salesdeity is offline
Old 01-05-2015 | 06:52 PM
Thanks, I think I will try the 26p first.
How many hours on your 525 and have you done the spring change/upgrade?
papps is offline
Old 01-06-2015 | 07:38 AM
I have ~150 hours. Engine is untouched. From the rpms you're turning with the 28" wheel, your engine seems healthy. To get the top speed, I run the drive at 4.5 and the tabs all the way up. Keeps it interesting that way.
Old 01-06-2015 | 08:00 PM
Last question.......are you running a RH or LH prop?
I am at 190 hrs with no issues. Typically run the drive at 5 and tabs at 2 but don't spend enough time at WOT to be able to say that is the fastest setup.
papps is offline
Old 01-07-2015 | 07:35 AM
Rh.
