Can you identify this transmission? >
Old 12-31-2014 | 10:50 AM
Default Can you identify this transmission?
Hi folks ,
Maybe a easy question but...
From the photo.. can you identify what transmission is connected to this motor? Also would anyone know anything about this type of transmission ?
The engine is a big block mercury racing motor from approximately 1990.
thanks a million!
[ATTACH=CONFIG]535035[/ATTACH]
Attached Thumbnails Can you identify this transmission?-motor-1-800x600-.jpg
xxxxxxx1 is offline
Old 12-31-2014 | 10:53 AM
it is a plug in trans,looks like a bam marine.
mike tkach is offline
Old 12-31-2014 | 11:53 AM
14 apache's Avatar
Originally Posted by xxxxxxx1
Hi folks ,
thanks a million!
Like Mike said its a plug in for a speed master 3/4/5 10-18 velvet drive could be modified by Huber marine or bam marine.
14 apache is offline
Old 12-31-2014 | 12:22 PM
Could be a stock Borg 72c, looks like the engine is a 420 merc
Unlimited jd is offline
Old 12-31-2014 | 12:50 PM
BUP
The transmission ID plate should be located if I remember correctly under the starter (left side, on top of the trans) ?
next IMO it looks like what merc use to call this transmission a Velvet Drive (Borg Warner 72 CR) could be wrong - going back some years now, off the top of my head.
If the trans ID plate is under starter it should have listed the Model #, gear ratio, serial # and ID plate model color code if any of this is still readable.
BUP is offline
Old 12-31-2014 | 06:08 PM
Thanks for the insight, I will look on the unit for a plate with any numbers or info.
This velvet drive...is it a good trans?.. great type of unit? ...common application ?..
Thanks so much for your expertise everyone.
xxxxxxx1 is offline
Old 12-31-2014 | 06:42 PM
Yeah kinda common. Like every boat with Ssm, 3,4,5,6's unless they have crash boxes, and any tr or trs boat with a 370,400,420 or bigger power.
