Cams For Sale Two new 741's and Two Custom Grinds.....
Have two new Crane Cams Part Number: 168741
Intake Duration at 050 inch Lift:236
Exhaust Duration at 050 inch Lift:244
Duration at 050 inch Lift:236 int./244 exh.
Advertised Intake Duration:298
Advertised Exhaust Duration:306
Advertised Duration:298 int./306 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.610 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.632 in.
Valve Lift with Factory Rocker Arm Ratio:0.610 int./0.632 exh.
Lobe Separation (degrees):112
Grind Number:HR-236/359-2S-12 IG
Also have two 100 hour Comp Cams, Custom Ground Part Number: P5710
Intake Duration at 050 inch: 224
Exhaust Duration at 050 inch: 230
Intake Valve Lift with Factory Rocker Arm Ratio:0.598 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.640 in.
Valve Lift with Factory Rocker Arm Ratio:0.598 int./0.640 exh.
Lobe Separation (degrees):114
Grind Number:HR14-31193111
Note: These are all (741's and P5710's) small snout Gen 6 cams
Will sell the 741's at $300 each Shipped Lower 48
Will sell the P5710's at $150 each Shipped Lower 48
Can send pic's if needed, feel free to call 503-910-4735 Pete or Email [email protected]
741's are sold, feel free to make offer on the P5710's
