Need FlyWheels...Internally Balanced >
Old 01-07-2015 | 03:22 PM
Default Need FlyWheels...Internally Balanced
Just pulled the 420's with TRS Drives....Building all new 572's with Konrads.....The Flywheels on the 420s are ext Balanced so I want to keep them with the motors (these are For Sale BTW!) Starter are Bell Housing Mounted.....BIG HEAVY Flywheels on these! Where can I get NEW ones??!! Im a Car guy,,,new to the Boat thing....Everything is a little "different"! Thanks, Tim Also have TRS's For Sale!
TAStevens is offline
Old 01-07-2015 | 03:28 PM
GPM
Summit, Jeg's
GPM is offline
Old 01-07-2015 | 03:32 PM
Really?? Don't see them in the books?
Old 01-07-2015 | 03:49 PM
just look up 168 tooth 396-427...now here's the kicker, they will not have the ring gear on the right side, some have both side machined for it and can just heat and swap over, if not need a machine shop to machine it for the other side...you can also try auto parts stores and maybe be able to find the ones already cut on both sides..I've had them both ways..good luck
ezstriper is offline
Old 01-07-2015 | 05:03 PM
Teague has them!
KWright is offline
Old 01-07-2015 | 05:41 PM
Thanks! Just ready to Balance....NEED Fly Wheels!
Old 01-07-2015 | 08:17 PM
I have had the machine shop mill the counter wieghts off. I have had it done a couple times its not a big deal.
1BIGJIM is offline
Old 01-08-2015 | 04:36 AM
Thought about doing that....but thought it better to keep on the 420,s for Re Sale?
Old 01-08-2015 | 06:39 AM
Ayuh,.... You can always get a Truck flywheel from yer local GM Dealer,....
Bondo is online now
