Trim Indicator questions
So my 30 concept(twin Merc Optis) currently has no motor or tab position indicators. The boat had trim tab indicators but the electronic display/controller is bad. Anyhow I am interested in going to a full manual indicator system from stainless marine. Its about $900 for the complete kit that I would install myself. The main question that I have is for someone that has a manual setup now. Where do the cables for the motor actuators exit the transom? Do they go thru the transom into the bracket and then exit the bracket? Or do the cables exit the transom above the bracket and go directly to the motor? It seems exiting the bracket would make the cables to low? But exiting the transom above the bracket would clutter up the area between the transom and the bracket? Anyhow pictures of a manual setup would be appreciated!
John
John
I have looked at those and been in contact with Mark the owner. He seems like a nice guy.
mine exit the transom through a stainless 45 degree compression fitting. I plan on going down to my boat this weekend in storage. I can take a picture if you'd like? I have the indicators you posted above.
Phil
Pete, I dont have gauges in the dash for the motor trim...they were removed to make room for the 13" garmin screen. There isnt room for any more gauges on the vertical portion of the dash. I supose there is room on the lower portion of the dash.
