Crane 741 or 525 efi cams >
Old 01-09-2015 | 08:03 AM
Default Crane 741 or 525 efi cams
Looking for a set of Crane 741 cams or Merc 525 EFI cams. Let me know what you have.
endeavour32 is offline
Old 01-09-2015 | 09:11 AM
TomZ's Avatar
You could use a Gen VI timing set with your MK IV block to run the 525 cam. That's what I'm doing with mine.
TomZ is offline
Old 01-09-2015 | 09:13 AM
Did you use a retainer plate as well... Right now I'm using a button in my current roller set up?
Old 01-09-2015 | 09:28 AM
TomZ's Avatar
I'm looking at the part right here in my office...
It uses a single roller chain and gear set with a retainer plate. Comes with the plate, bolts, gears. Bolts to the same retainer boss on the MK IV block that is used for gear-driven timing sets used on HD trucks. All 454s have the provision. I think I paid $50 for the whole thing off of eBay.
[ATTACH=CONFIG]535420[/ATTACH][ATTACH=CONFIG]535421[/ATTACH][ATTACH=CONFIG]535422[/ATTACH]
Attached Thumbnails Crane 741 or 525 efi cams-gm-g6_timing_set.jpg   Crane 741 or 525 efi cams-gm-g6_timing_set-2.jpg   Crane 741 or 525 efi cams-gm-g6_timing_set-3.jpg
TomZ is offline
Old 01-09-2015 | 09:38 AM
TomZ's Avatar
And just incase you cannot see the pics I posted... the part number for the timing kit is:
GM Performance Parts 12371053
TomZ is offline
Old 01-09-2015 | 03:45 PM
Thanks for the info!
