Winterizing fountain 33 fever. 502 mpi. >
Old 01-11-2015 | 03:54 PM
Default Winterizing fountain 33 fever. 502 mpi.
Does anyone have a step by step instruction to winterized my 1998 fountain fever with 502 MPI?
Thank you
chriskinney15 is offline
Old 01-11-2015 | 04:13 PM
It's half way through January. Not too late is it? Can't see where you're from.
sea6 is offline
Old 01-11-2015 | 04:24 PM
You mean 32 fever? The 32s are tight..you be better off draining the exhaust manifolds removing the lower water pump J hose and draining as much of the engine as possible..put a large bucket underneath the Out drives to catch The antifreeze as the engine is running,get some flexible 4 inch hose like dryer vent hose the aluminum type, put it on the exhaust Tips and the other end into the bucket so you can recirculate the antifreeze as its coming out,Fill the bucket with straight antifreeze, connect the muffs to a sump pump, start engine and keep running it until the thermostat opens and the antifreeze mixes in the engine .once thermostat is opened up check the strength of the antifreeze coming out of the exhaust tips, add antifreeze to the bucket as needed
boatnt is offline
Old 01-11-2015 | 07:15 PM
I do it like Boatnt except I remove the thermostat housing pull the thermostat, the replace the housing then do what he says. I just put the thermostat back in the spring. Shut the fuel line lever to off and your done.. They do sell the 5 gallon jugs at marine stores that have a diverter valve for the mixture that makes it easy.
tbrown15239 is offline
Old 01-11-2015 | 08:24 PM
Thanks guys. It's already winterized just wanted the info for myself.
Old 01-12-2015 | 12:12 PM
Thank you
There is a HUGE thread on here I read about winterizing and unwinterizing. I found it when I first got our boat it was very helpful!
http://www.offshoreonly.com/forums/g...-full-way.html
Diamond Dave is offline
Old 01-12-2015 | 01:31 PM
My suggestion to you and anyone else that does their own work is to replace the 1/4 inch plugs on each side of the block with ball valves. The ball valves are made in brass and stainless steel...pick whichever you want to use. You will need a 1/4" nipple 3 inches long, a 1/4 to 3/8 adapter and a 3/8 ball valve. Use a 3/8 ball valve because the handle on a 1/4 is just too small. It's tough to get in there to get the inside plugs on a twin, especially tough on a fountain but it can be done. Assemble all three parts using teflon tape and tighten them up, then install it into the block and tighten it so that the ball valve handle is easy to get to. Next time you need to winterize and drain the water from your engine(s), all you have to do is reach down and turn the handle on the ball valve 90* to drain out the water. After the water is out, you can reach back down and close the valves and then fill the motor(s) with the pink stuff antifreeze or not. Pull the bottom hose off your sea pump and drain your exhaust and you are done. It takes me about 20 minutes to winterize my twin.
pslonaker is offline
Old 01-12-2015 | 03:37 PM
Don't just open the valve, visually see that water is flowing out the valve otherwise the block or valve is clogged with sand which needs to be removed using a nail, ice pick etc.
Also, many of the Fountains have the water pressure pick up located at the port side drain so the hose must be removed to drain the block.
Interceptor is offline
Old 01-12-2015 | 03:53 PM
My 95 32 Fever has hoses there if I recall but an easy way to drain the blocks would be nice. I "winterized" mine in September here in Oregon but I don't remember if there was a drain on the other side of the blocks as well that I used? Hmmm...makes me want to uncover it and check! Nah...It's too damn cold out still!! Lol
Old 01-12-2015 | 04:23 PM
There is a drain plug for each side of the block and each side must be opened up or you drain one side while the other is still full. If you cant see water coming out, or feel water coming out when you open the valve, then yes, you will have to poke something up it to clear out any junk blocking the flow. A 6 inch 1/8 drill is good as you can turn it by hand and it will dig its way in if necessary. Another thing that you can do when boating is to have the motor(s) running and before the exhaust gets too hot...open the valves and let the water pressure blow out any junk that might be trying to plug it up.
As for a hose connected to a drain...move the hose to the back of the intake manifold.
