Procharged 502 Mag Oil Cooler Recommendations >
Old 01-12-2015 | 07:48 AM
Default Procharged 502 Mag Oil Cooler Recommendations
I searched and searched, nothing I found could help...
Winter upgrades will include installing a couple of new M1-SC (with associated upgrades & programming) to two 502 MAGs.
I know there are many items that are needed for the 502's to live a long, happy, healthy life so I am compiling some necessary info. The first being upgraded oil coolers.
What is available? Does anyone have any recommendations? These are going in a confined engine compartment of a BAJA BOSS 302.
I am already dealing with slight oil pressure drop at or near WOT for any extended period due to rising oil temps.
justinp20012500 is offline
Old 01-12-2015 | 07:59 AM
Call Mr. Cool great prices quality pieces.
Black Baja is offline
Old 01-12-2015 | 08:33 AM
I used a eddie marine large cooler, block adapter, filter mount and #10 lines, the merc stuff is junk, need to redo fuel system as well to make live with the procharger...
ezstriper is offline
Old 01-12-2015 | 08:53 AM
Planning on it. Going to pull the rails and send them to Eddie Young to be modified.
What is anyone's thoughts on using this adapter for a wide band 02 sensor?
http://www.ebay.com/itm/310137061646...%3AMEBIDX%3AIT
Have something better?
Old 01-12-2015 | 11:36 AM
I did not have good luck with Mr. Cool. Sent me exactly what I told him I didn't want and then would not return my phone calls. I would place him in the "scheister" category.
liquidlounge is offline
Old 01-12-2015 | 03:55 PM
GPM
Maybe one of these would work for you, http://www.cpperformance.com/c-731-t...l-coolers.aspx
GPM is offline
Old 01-12-2015 | 04:04 PM
I am also shopping oil coolers for my M3 Procharged 502. Last year I ran the stock oil cooler. With no thermostat my engine runs around 110 degrees water temp. My oil would never warm up above 110 degrees until I ran the boat hard. For that reason I am considering one of these. http://www.cpperformance.com/p-26867...k-adapter.aspx
hadleycat is offline
Old 01-12-2015 | 06:52 PM
The thermostatic adapter the Hadley referenced is a great choice. We have used quite a few of them. There were some issues with the first few, but they have that worked out now.
As for a cooler, a cooler with a 3" x 12" bundle from Hardin will do just fine at that power level. A cooler with a 3 x12" bundle will be about 16" long overall. That will cool up to 700-750 if you run it really hard, and quite a bit more if you only run it really hard periodically.
Eddie
Young Performance is offline
Old 01-13-2015 | 09:15 AM
Eddie
Thanks for the Cooler size info Eddie
Old 02-06-2015 | 10:45 AM
I am having Eddie do my fuel system which requires the elimination of the cool fuel and pump.
Is there an oil cooler that can go in place of the cool fuel? I will pick up the thermostatic adapter to run with one if I can get it to fit.
Seems like a good location.
