Diameter vs. Pitch
Can someone tell me in layman's terms, what the relationship between prop diameter, pitch, and speed is? Is the difference in diameter of the same pitch prop proportionate to slip?
Thanks,
Dumbo
Thanks,
Dumbo
Blade design plays a bigger roll than diameter,.... especially with efficiency/ slippage,...
The larger the diameter the prop will have more blade surface area thus creating more effective (higher) pitch. So say if you have a prop with 14 7/8" 32pitch and another prop with 15 1/4" diameter 32p, the larger diameter will be lower rpm and act as if it were a larger pitch than the smaller diameter prop even though they are both "labeled" as 32 pitch. Larger diameters can offer benefits when needed such as lower slip numbers on high x boats and also minimize blowout
Diameter is good, when its needed, bad when its not. I think you'll find on boats where the propshaft is deep, adding diameter usually will slow the boat down at top speed. Kind of like on a boat where 3 blades are the fastest after realizing 4 or 5 blades just slowed it down.
More diameter creates more stern lift. We use diameter in a variety of set up desires.
As manufacturers of propellers, we determine the best all around diameter for any given propeller design based on its most common usage. As custom propeller tweakers, we adjust that diameter when needed to get the affect desired.
There is a ton going on with diameter adjustments.
Brett
[email protected]
[email protected]
Sorry I missed this response.
Actually you can weld on diameter but it is not a very good idea in performance applications because of the risk of failure.
Brett
Brett
[email protected]
[email protected]
