Leaking Trim/Trim Tab Pumps >
Old 01-15-2015 | 11:44 AM
Default Leaking Trim/Trim Tab Pumps
All my pumps leak into the bilge under the pumps. I am tired of cleaning up the mess. I think that the reservoir or the caps on the reservoir are leaking.
Has anyone used the billet trim/tab reservoir made by GRP. They have billet caps and clear round Lexan reservoir body. Did they stop all the leaking mess?
Bama is offline
Old 01-15-2015 | 12:28 PM
Dave M's Avatar
Veteran: Navy
I can't answer about GRP.
I did a cheap fix on my previous boat. I fabricated a couple of 12* blocks to go between the transom and the pump mounts. I think they leak because of the angle of most transoms. No more leaks!
Dave M is offline
Old 01-15-2015 | 12:45 PM
obnoxus's Avatar
Charter Member #1171
http://www.diamondperformanceparts.c...roductid=16563
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 01-15-2015 | 04:18 PM
Dave M's Avatar
Veteran: Navy
With mine, it wasn't the caps leaking. It was where the reservoir meets the pump body.
Dave M is offline
Old 01-16-2015 | 08:49 AM
Same here. Mine leak sitting still on the trailer. Not enough to find the leak - just weeping from the pump/reservoir body, I guess.
ALL_IN! is offline
Old 01-16-2015 | 04:00 PM
The platic reservoir split on the seam over time and leak , happend to my trim pump reservoirs ..
paul buckner is offline
Old 01-20-2015 | 04:09 PM
Billet reservoirs are on order, anodized red. For $600.00 I hope they don't leak.
Bama is offline
Old 02-01-2015 | 08:22 AM
What reservoirs did you order BAMA?
I'm considering replacing 3 of mine with the GRP style.
But from what it looks like, the volume of fluid is cut in half from the plastic ones that leak.
OPIE272 is offline
Old 02-01-2015 | 09:25 AM
seen that many times.
sutphen 30 is offline
Old 02-10-2015 | 07:08 AM
Ttt
OPIE272 is offline
