Fortress Aluminum Anchors
Old 09-03-2002 | 11:05 AM
bn
Default Fortress Aluminum Anchors
My brother lost my anchor this weekend and I am looking to replace it. I was just on the Fortress Anchor website:
http://www.fortressanchors.com/index.html
and I am wondering if anyone has had any experiance with their less expensive model - The Guardian?? I know people that have the Fortress and they all think it's the best anchor. Is this Guardian model any good or should I buck up and buy the Fortress?
Also, is it easy and quick to assemble and dissemble?
bn is offline
Old 09-03-2002 | 11:15 AM
fountain27ho496's Avatar
Default Buck up
Dont know about the guardian, have the small
fortress, 85.00, throw it in, and forget about it.
fountain27ho496 is offline
Old 09-03-2002 | 11:36 AM
Dock Holiday's Avatar
Charter Member #34
I did not have good luck with the Fortress.
Lost a cheap galvanized anchor that worked GREAT. Both a Fortress for the 27 Baja thinking it was the best. I purchased the correct size for the boat and it was a bear to get it to set and usually a good wake would pull it loose. I never overnighted with it because I was not comfortable it would hold. Ended up putting 8 feet of chain on it to make it work to suit.
Just yesterday we rafted up next to a 35 Formula and he put his Fortress in the water. We ended up with five boats total in 25 foot of water and the anchor let go.
I purchased a Box anchor for my 36 Outlaw I now have and I have to tell you it is the best Anchor I have ever owned.
I have had three boats rafted off of me and it never moves. If I had used my anchor yesterday we would have stayed right where we started.
The great thing is NO CHAIN REQUIRED, and you do not have to set it, just drop it in the water. The bad thing is they are a little heavy to bring back up.
Not bad mouthing Fortress, I just did not have good luck with it.
Buy a Box Anchor and you WILL be happy.
Mark
Dock Holiday is offline
Old 09-03-2002 | 11:40 AM
rv
I second what Dock said. Had both and currently own box anchor. Best one we ever had. He is right, you drop the anchor and it is set, no pulling needed or wondering if is has set yet.
Rick
rv is offline
Old 09-03-2002 | 11:51 AM
jokerswild
Delta anchor's are the best and worry free in tidal waters- period
Old 09-03-2002 | 12:05 PM
Tantrum's Avatar
I have the fortress and it is a bear to set. I put a stainless chain on to add some wieght. The nice part is the duffle storage bag and the light wieght which is easy on the boat. For 95% of my boating I keep the Fortress on board just so I have an anchor in an emergency. If I plan to raft up or anchor I bring the galvanized.
Tantrum is offline
Old 09-03-2002 | 02:11 PM
Tinkerer's Avatar
I have two FORTRESS anchors and my only complaint is the dam things set so hard that sometimes I can hardly pull them up. Even in a mud bottom. I have 10 ft of chain on them because that is the only way that they will set properly. At loto I had a hard time pulling it up. Everyone told me it was a rock bottom but I pulled up mud. Main channel and party cove both.
Tinkerer is offline
Old 09-03-2002 | 02:15 PM
CigDaze's Avatar
I have had great luck with my fortress anchor. I picked it up at Boat-US and there were two models side-by-side. One was expensive and the other was cheaper. They looked and felt identical except one was more shiny than the other. I opted for the cheaper one and it works great. It sets every time, the first time. Maybe they really depend on the bottom, but in FL sandy conditions, it works awesome. I've never had to worry about it.
Mines a #11 with about 6' of chain.
CigDaze is offline
Old 09-03-2002 | 03:13 PM
MitchStellin's Avatar
I have one you can buy. It is in perfect shape (how can you wreck an anchor) and is large enough for a 35 foot boat. I will go home and check the size. Call me at 616-546-6309 days and i will get you the info. I have no idea what it is worth. Maybe $1,000? Just kidding. make an offer.
MitchStellin is offline
Old 09-03-2002 | 04:34 PM
formula31's Avatar
I also am a fortress supporter, #11 with 6' of 3/8 ss chain and the proper amount of 1/2" line and Ive never had it miss a hook up, even resets when the wind changes direction, have no problem sleeping on the hook with the fortress. I also have had troubles get it out sometimes, burys so deep.
formula31 is offline
