What cams will work with stock lifters. >
Old 01-20-2015 | 08:00 AM
Default What cams will work with stock lifters.
What cams will work with stock roller lifters and be reliable? 502 mag stuff.
Thanks.
indysupra is offline
Old 01-20-2015 | 09:52 AM
Full Force's Avatar
up to .578 lift safely.....
Full Force is offline
Old 01-20-2015 | 11:02 AM
I would say something that requires less than 150# on the seat, but maybe its the over the nose pressure you need to be more concerned with. Bob M. could speculate better on this.
liquidlounge is offline
Old 01-20-2015 | 11:31 AM
They break the axle and roller in hp500's I wouldn't use them with anything more than stock. I don't even put them back in for stock motors
Unlimited jd is offline
Old 01-20-2015 | 12:21 PM
That takes care of that idea. Sucks there is not a cheaper alternative to stock roller lifters. The morels are a lot of money.
Old 01-20-2015 | 12:55 PM
I've ran .595 on gen6 block with stock lifters
Black Baja is offline
Old 01-20-2015 | 01:14 PM
I've done just don't reccomemd it.
Old 01-20-2015 | 01:38 PM
Ahhh now the truth comes out.
Old 01-20-2015 | 01:53 PM
Full Force's Avatar
I am spending an extra 10,000.00 this winter to get rid of parts that "might" be ok..... reliability costs $$$
Old 01-21-2015 | 08:16 AM
I'm pretty sure the hp rollers never used the stock GM lifter , but I do remember them wrecking the Crane rollers and that may have had more to do with the spring than anything else.
