Looking for Mercury Jackshaft parts >
Old 01-22-2015 | 06:46 AM
Default Looking for Mercury Jackshaft parts
Hello Folks
I'm in the process of building a classic runabout wooden boat 29' feet long. Searching for the jack shaft components for a Mercury Marine outdrive. Can anybody help with some or all parts?
Thanks, Jim
Happyours1 is offline
Old 01-25-2015 | 03:30 PM
Mbam's Avatar
Offshoreonly Advertiser
Which drive?
Mbam is offline
Old 01-25-2015 | 04:56 PM
Originally Posted by Mbam
Which drive?
Ayuh,.... I don't believe the jack-shaft driveline cares which motor is ahead of it, nor which drive is behind it,.....
The forward assembly has to mount to the motor, 'n if Chevy based power, they'll all interchange,....
The aft connection is standard Merc rear motor mount/ transom mountin' patterned,....
Bondo is offline
Old 01-25-2015 | 06:35 PM
Mbam's Avatar
Yes the forward assembly mounts to a standard velvet-drive style housing, But the rear mounts to the inner transom plate. The older drives have a different plate than the newer. And I am pretty sure all that is available today is the later style tailstock.
Actually now that I think about it I am pretty sure you could use the new inner on an older drive if you have to. In any case you can fins the pieces here:
http://www.mercruiserparts.com/Show_...%2898634A13%29
Mbam is offline
Old 01-25-2015 | 06:40 PM
Mbam's Avatar
Here is a link to the latest version of the kit
http://www.mercruiserparts.com/Show_...shaft+Main+Kit
Mbam is offline
Old 01-25-2015 | 09:10 PM
I have a 305 SBC with a Alpha drive. I did come across a complete kit someone has. The kit has a bell housing for a big block... will that fit my 305 ?? I'm thinking it will. Your thoughts ???
Jim
Old 01-26-2015 | 04:49 AM
Jim
Ayuh,.... It will fit,.... The Chevy flywheel covers fit anything from a 2.5l I4 to the BBCs,...
Bondo is offline
Old 01-26-2015 | 06:09 AM
Thanks for the info !!
