Marvel Mystery Oil for Fogging?
my fuel tank is 200 or 250 gallons so i put in a quart for each 100 gallons. about 1/2 quart for each motor to winterize. just don't pour it too fast. it doesn't compress and needs to atomize in your venturii's. i also use a biocide in the fuel because there were some nast little organisms plugging up my carb one spring. don't forget to fill your tank so the expansion and contraction of the gasoline won't draw humidity through your vent and condense water back in your fuel. if you can help it, fill your tank as soon as you winterize. gasoline manufacturers "hide" more butane in the fuel in the colder it gets. vapor lock is caused by butane turning back to gas from a liquid when it reches it's boiling point which isn't very high. that first warm day when you run the boat next spring it vapor locks and people always ask why.
