prop rotation in or out on cats >
Old 01-26-2015 | 12:28 PM
Default prop rotation in or out on cats
Just curious what rake props and rotation most are running on cats.
skate 36 is offline
Old 01-26-2015 | 12:38 PM
weldcrane's Avatar
On my 35 motion turning in
weldcrane is offline
Old 01-26-2015 | 02:32 PM
flight club's Avatar
out for speed, in for handling. 16 or 18 on rake
flight club is offline
Old 01-26-2015 | 02:36 PM
+1
phil_p999 is offline
Old 01-26-2015 | 02:56 PM
whats different with the handing? I always hears that out is better in rough water.
skate 36 is offline
Old 01-26-2015 | 03:37 PM
GATORONE's Avatar
It all depends on the boat, type of drives... Lots of variables.. As Ron said 16-18 degree rake but the diameter depends on the boat.. It's sort of a loaded question
GATORONE is offline
Old 01-26-2015 | 03:47 PM
Average would be 18 turning in. Lower rake will generally lift transom and higher rake allows more bowdise . In most cases turning out will give more transom lift(think about water coming off the deadrise of fhe sponson with outward rotation. The blade moving downward will contact the water much sooner in the stroke than if turning inward.) Of course there are many other variables.
SkiDoc is offline
Old 01-26-2015 | 03:50 PM
Just switched to out ( 36 NT), picked up 8 MPH and handles good. when turning in it felt like it was picking the back of the boat up to much....18 rake.
Bill fountain40 is offline
Old 01-26-2015 | 04:08 PM
I am getting close on completing a 36 Nortech 800hp .trying to pick props and set-up. In or out. Thanks for the input.
skate 36 is offline
Old 01-26-2015 | 09:09 PM
SummerObsession's Avatar
predisiondetails in 3....2....1......
Lol just messing with you PD!
SummerObsession is offline
