Props and speed of a 95 stepped 42 on boxes??? >
Old 01-27-2015 | 02:13 AM
Default Props and speed of a 95 stepped 42 on boxes???
I just bought a 1995 stepped 42 with new side by side HP 500s and boxes that are up 3 inches, the boat did not come with props and the owner knew nothing of high-performance boating at all, what do you guys think I should start with four props??
Has anyone ever had a similar set up and if so how fast did the boat run in with what props?
adrenalinejunkey is offline
Old 01-27-2015 | 08:53 AM
Ran-Dom 32's Avatar
boat should run low to mid 70's with HP 500's , you may need 5 blades if your x-dim is up 3" from stock height, most stag 42's with hp 500's had 26' hydro or 28 Bravo 1 4 blades, that would be a good place to start, good luck
Ran-Dom 32 is offline
Old 01-27-2015 | 08:57 AM
jbraun2828's Avatar
Buddy of mine has a 95 with around 650 a side. He runs about 83-84
jbraun2828 is offline
Old 01-27-2015 | 04:25 PM
I wouldnt think 3 inch raised boxes, would be very beneficial with stock 500's. Throw some 850s in it!
MILD THUNDER is offline
Old 01-27-2015 | 09:22 PM
Thanks guys!!!!! The boat is a side by side, my plans are to add a pair of 8-71's or 3.3 carbed whipples at some point if I can find some and set them up to make 700-750.
Old 01-31-2015 | 10:30 PM
Bump
Old 01-31-2015 | 10:46 PM
another bump for reminding you to post pics!! congrats!!
nailit is offline
Old 02-25-2015 | 12:11 AM
Bump
Old 02-25-2015 | 12:55 AM
Being on boxes your drives wont feel like they are raised 3 inches. Mine are on boxes w/ 2 inch shorties which equals out to around a 1/2 inch above factory depth. You'll prolly be to deep for 5 blades.
jmoore1225 is offline
Old 02-25-2015 | 10:10 AM
What do you have for a boat, power, props and speed?
