Mercruiser 383 MAG MPI attached to a Volvo Penta Duo outdrive possible? >
Old 01-29-2015 | 08:08 AM
Default Mercruiser 383 MAG MPI attached to a Volvo Penta Duo outdrive possible?
Hey guys there offering me a Mercruiser 383.. 0Hrs dirt cheap..fuel injected which is the main reason i would wanna swap.... I wanted to know if it was possible to mate this with my Volvo duo prop....im currently running the Volvo penta 350 small block with the duo.. i figured i could swap out the bell housing and flywheel off my current setup, add the sea pump and be good to go? anyone see why not? both basically Chevy at the core? Transom cutout for my Volvo is the same as the mercruiser, i could always go that route and swap everything out but i figured ill try to save my expensive Volvo drive..
NewBanana is offline
Old 01-29-2015 | 08:29 AM
I really have no idea, but my buddy in his Cobalt has a Volvo engine with a Merc outdrive so....maybe!!!
Captain YARRR is offline
Old 01-29-2015 | 01:01 PM
lmao!!!! thats what i like to hear sounds positive to me..lol
Old 01-29-2015 | 01:13 PM
It will bolt up .
paul buckner is offline
Old 01-29-2015 | 07:15 PM
BUP
No problem at all but possible prop change to maintain recommended rpm range. If your Volvo engine was the 5.7 GXi - 315 hp then most likely not even a prop change. Simple install as the biggest change was the color going to black now for the engine.
BUP is offline
Old 01-30-2015 | 09:11 AM
Great that's what I thought.. I pick up the engine this afternoon.. I'll keep u guys posted but I'll probably install it at the end of this season..already have the boat on the rack so I'll wait
