A/F Ratio
Like he said. While 14.7 is stoch, best power can be anywhere from 11.7:1 to 12.8:1 depending on the motor.
Now, don't confuse widebands O2 readings on dyno sheets for what the dyno computes as AFR. I have seen them very as much as two points.
Therefore, all data you see is measured at WOT...including A/F ratio's.
Not on everyone's dyno. ;-) I make pulls at different throttle positions to verify that the tune up is right. I have seen a few different carbs come in with tuneups that have caused motors to melt down at cruise. They were right at WOT but 19:1 at partial.
