New Hydraulic Billet Trim Tabs are making their debut at the 2015 Miami Boat Show, B
These new billet trim tabs are available for electronic or mechanical trim indication. Livorsi's billet trim tabs stretch across the boating spectrum; models are available for performance boats, center consoles, cruisers, workboats, run-abouts and military boats from 20 to 50 feet.
Tabs are constructed from CNC machined billet aluminum with a Mil-Spec hard coat anodized finish, hinge pins that are stainless steel and with the use of 5 anodes, these tabs are designed for complete saltwater protection for years of reliable service with a beautiful finish.
The electronic sender models are capable of reading trim indication with compatible NMEA 2000® compliant systems and Mercury VesselView®. The electronic IP68 sensor used on these tabs directly plugs into Livorsi's LED Position Indicators for immediate indication.
Hydraulic cylinders are designed with dual seals and 1500 PSI working pressure. Bolt patterns include Mercury and a smaller Livorsi bolt pattern for center consoles. Transom angles on these tabs may be adjusted without the need for special tools making these tabs easy to install and modify for your application.
Come see our new interactive Trim Tab and LED Indicator display, Booth G90
Features:
- Models are available for performance boats, center consoles, cruisers, run-abouts, workboats and military boats
- For use on boats 20 - 50 feet
- Choose between LED electronic position indication (plug and play) or mechanical position indication (uses 33C cables)
- Electronic models are compatible with NMEA 2000® compliant systems and Mercury VesselView®
- The electronic IP68 sensor plugs directly to Livorsi's LED Position Indicator
- Tabs are CNC machined from billet aluminum, no casting
- Tabs are Mil-Spec hard coat anodized to prevent corrosion
- Bolt patterns include Mercury and a smaller Livorsi bolt pattern for center consoles
- All hinge pins and hardware are stainless steel
- Adjustable transom angles without the use of special tools
- Hydraulic cylinders are designed for 1500 PSI working pressure with dual seals
- These cylinders may be serviced
- Five anodes for complete saltwater protection
- Stainless steel braided hoses sold separately
