Stupid Prop Question
Old 09-03-2002 | 11:54 PM
puder's Avatar
speel chekk this fokker!
Default Stupid Prop Question
Just cus i'ma spaz i wanted todouble check standard bravo rotation is righthand right??? Seeing as my new engein is on its way I will be needing a different prop. I had a 19p Mirage+ with 1.32 gears on an alpha drive witha 330HP BBC.
I now will have a 550hp BBC with a 1.5 bravo. I think the 19p is gonna be WAY to small I figure i will need a about 26p bravo1. I figure that is a good starting point. What is the pitch difference between a Hydro and Bravo. I was also thinking i might try one of those older merc 5 blades. Were they decent or crap. I am looking for a fast cruise not all out speed.
With the old drive engine setup the boat felt much better with the mirage+ than the plain old mirage.
But my stupid question is i need to buy a right hand rotation prop.
Pardon me, while I whip this out!
puder is offline
Old 09-04-2002 | 07:38 AM
laster's Avatar
Actuallly, with a Bravo drive you can turn it either way. Preferred is right hand. I expect you will probably want something smaller than the 26 but that is just a guess. Remember you will probably have a difference in RPMs to consider as well as the gear and horsepower changes. A Hydromotive prop will seem to have more pirch compared to a Bravo because of the way each is measured. A 24 Bravo should run in the vicinity of 70 depending on RPM and slip. Keep us posted.
laster is offline
Old 09-04-2002 | 07:58 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Puder
My brother laster is right you can spin it either way.....26 is way to small though bro....On the factory boats were running 28-33 pitch props.....Now then have I gotta surprise for you stud! I happen to have something very unique that i want you to try out.....Is it a big shaft bravo or small shaft bravo?????? Call me 856 498-9606.......Don't call until thursday though as I am about to walk that isle brother.......
Sean
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 09-04-2002 | 01:05 PM
puder's Avatar
good luck with the wedding!!!!
are you going to be at the NYC race???
puder is offline
Old 09-04-2002 | 01:37 PM
Charter Member #38
puder,
What kind of rpms do you want to run ? or what kind of rpms will the motor run ? You have a single engine application correct ?! What length boat ?
I have a single 550HP Baja, 28'. I run a Mirage Plus 25, @5000rpms. I ran a Bravo 1 24 @ the same rpms. You may want to get your hands on a Bravo 1 26 and run it(try it before you buy it). See what it does for you. I run the Mirage Plus because speed was a bigger concern. The Bravo 1 's will defintely give a better "cruise" and hole shot.
I think a twin application could use larger pitch props (28-33).
hotbeek is offline
Old 09-04-2002 | 04:53 PM
puder's Avatar
my WOT should be about 5300.
but my cruise RPM is 4500-4700. That is were the VE numbers are the best BUT 4700 is kind of high.
the boat is a 26' scarab excel single 550hp 454.
puder is offline
Bryan Rose
8
03-01-2008 11:00 AM
tjtyler
Baja
1
08-19-2007 12:57 PM
dhlaw
12-02-2003 10:36 PM
JUSTONCE
General Racing Discussion
7
01-08-2003 10:46 AM
Dock Holiday
2
09-21-2002 10:43 AM
