Does anyone know where I can get the wiring diagram for a 2000 Scarab 33 AVS? >
Old 02-09-2015 | 01:36 PM
Default Does anyone know where I can get the wiring diagram for a 2000 Scarab 33 AVS?
Thanks,
Cyrus
cyrus77 is offline
Old 02-09-2015 | 02:21 PM
If you go to wellcraft.com they have some old manuals you can download. Not sure if you will find this but it is a start... Look under resources...
msher44 is offline
Old 02-09-2015 | 02:23 PM
Look under resources tab...
msher44 is offline
Old 02-09-2015 | 05:01 PM
I found the owners manual, but I can't locate any wiring diagram.
http://wellcraft.com/downloads/owner...carab_2000.pdf
cyrus77 is offline
Old 02-10-2015 | 03:40 PM
Try John Mossetti.
msher44 is offline
Old 02-22-2015 | 12:08 AM
Is John Mossetti on here? or elsewhere. Thanks.
cyrus77 is offline
Old 02-22-2015 | 08:49 PM
Rookie's Avatar
What wiring schematic do you need to know? If it has a Mercruiser engine then it will be their wire harness and color codes. Anything else cockpit, bilge lights should be easy to trace.
Rookie is offline
Old 02-22-2015 | 08:52 PM
Rookie's Avatar
Try here.
http://www.marinemechanic.com/site/page19.html
Rookie is offline
Old 02-23-2015 | 06:55 AM
scarabman's Avatar
Yup.. Merc on the engines/components, and ABYC standard on everything else.
scarabman is offline
Old 02-23-2015 | 07:56 PM
Rookie's Avatar
http://www.pkys.com/Reference.htm
Rookie is offline
