Bravo flywheel housing 8 plate oil cooler mounting >
Old 02-11-2015 | 07:28 AM
Default Bravo flywheel housing 8 plate oil cooler mounting
Wondering if there is a way to mount an 8 plate Mercury racing style oil cooler to a bravo late model flywheel cover(upper) like CP/hardin offers? The 8 plate coolers have a 3 point mount, and I'm curious if it matches up to the holes found on late model flywheel covers( the three holes attach the factory power steering cooler.) Here is what I'm referencing.
http://www.cpperformance.com/p-14605...ooler-kit.aspx
chrisf695 is offline
Old 02-11-2015 | 11:11 PM
You can fab up a step of bracket out of aluminum. That's my plan.
Borgie is offline
Old 02-12-2015 | 11:11 AM
Anyone?
Old 02-12-2015 | 12:14 PM
bcfountain's Avatar
Registered User
Originally Posted by chrisf695
Anyone?
chriss.my buddy has a 32 Baja that is a bravo boat.he has new plate coolers on both motors.i want to say they came from cp.but not sure.they are mounted on the back of the block.and water is piped through the cooler.they are mounted on a angle.probley on the threaded bosses on the block.i have a trs boat that uses plate type coolers but the bolt into the bell housing.i will find out what kind my friend is using.
bcfountain is offline
Old 02-13-2015 | 06:07 AM
Ayuh,.... Even if it don't mount as ya want it too,....
It shouldn't be very tough to fab up a bracket to mount it,....
Bondo is online now
Old 02-13-2015 | 12:13 PM
I'll probably use a piece of aluminum channel and do a step off mount. Appreciate the input guys!
